sporatic knock
Then again, over-active knock sensors can cause the problem too.
Start from a stock binary, and set your PE table to what you want your afr to be. Then using a wideband, tune the VE table in open loop, tune the MAF table in open loop, restore closed loop and allow the STFTs to control day to day fuelling. Then fix any timing problems. My guess is that you won't have any.
