Desifer this for me..
Old Feb 6, 2007 | 12:46 PM
wait4me's Avatar
All our customers always get free updates for life anyways so If they ever want to change anything, that is never an issue.
thanks guys.
Old Feb 6, 2007 | 01:38 PM
04BlackGmc's Avatar
Never said i had a issue with you jesse. Just trying to figure out things. not trying to down anyone here.
i just feel my truck should be a little stronger with mods, and just making sure that i am getting what i can outta of a tune, but im also not saying im expecting the world.
Old Feb 6, 2007 | 01:44 PM
wait4me's Avatar
I understand that.
You cant add any more timing to it or it will ping.
and the difference between a 12.5 to a 12.8 airfuel ratio is not going to make a major change in hp on that engine. 1-2 hp tops.
If you want more power, usually the best thing to do is add a cam. It is the major restriction on that engine. You can only squeze so much out of the computer/other engine parts.
Old Feb 6, 2007 | 01:46 PM
04BlackGmc's Avatar
pm sent jesse
Old Feb 6, 2007 | 10:25 PM
Tech's Avatar
Well, ideally your LTFTs would be 0 or slightly negative under partial throttle. If they are positive when you go WOT, they will offset your PE table. If your question is if your positive LTFTs are hurting your power, the answer can't be determined without a more information (wideband). No matter what your LTFTs are at WOT, your PCM is trying to hit your target WOT AFR. As long as they aren't pegged, your WOT AFR should be close. So close it wouldn't be worth more then a few HP.
Old Feb 7, 2007 | 02:47 PM
04BlackGmc's Avatar
under partial throttle they also are around +4-7...
Old Feb 7, 2007 | 02:55 PM
SSpdDmon's Avatar
See Tech's response... (same as what we've been telling you from the start)
Originally Posted by Tech
Well, ideally your LTFTs would be 0 or slightly negative under partial throttle. If they are positive when you go WOT, they will offset (add the percentage to) your PE table (increasing the amount of fuel delivered). If your question is if your positive LTFTs are hurting your power, the answer can't be determined without a more information (wideband). No matter what your LTFTs are at WOT, your PCM is trying to hit your target WOT AFR. As long as they aren't pegged, your WOT AFR should be close. So close it wouldn't be worth more then a few HP.
Old Feb 7, 2007 | 02:58 PM
04BlackGmc's Avatar
thats what i thought... thanks!
well ill post the dyno sheet soon after this sunday.
