Hey guys I just got my wide band/gauge set up in the car. Previous to this I had made tuning adjustments for part throttle and rescaled the lower part of the MAF table. I figured I was rich @WOT and found the gauge to display 12.5 I was a little supprised it was that close to ideal A/f ratio. So far all of the tuning has been to lean the car out little and appears to be the case for WOT also. I was under the impression I would be seeing the tune be off more that it has been. The car has a complete set of boltons, etc.
Is it worth my time to adjust for the 12.8 A/F ratio from 12.5 at WOT? My injector duty cycle is just under 80% @ WOT I was suprised to see this also for just a bolt on car.
I have N20 in mind a 75 shot, look's like injectors are a must at this point?
