TCS off light coming on?
It can also be caused by cam/tuning/intake airflow increases.
With a bigger cam than stock the PCM sees more air at idle than it should for a given throttle percentage and thinks the TPS sensor is whacked so it disables the traction control (and the switch won't enable/disable), and it falls to speed density when this happens.
If this is the problem you will often throw a P0121 TPS code. Replacing the TPS will not fix the problem, as the TPS is fine.
Raising your idle speed with tuning software (or EFIlive can adjust the actual expected idle airflow vs TPS) will normally mask the airflow reading problem enough to not throw the code and experience the TPS problem.
Cheers,
Rob (Bad30th)
The higher idle RPM sometimes straightens out the expected airflow somehow, at least it bandaided it for me... Mine was ~900-950 when I had my cam. I'm running an LS6 cam now, no problems.
Rob (Bad30th)
If the car is surging it needs to be tuned better, I don't see a cam in your sig - I also see you have ported MAF ends, put the screen and stock MAF back in and I bet it helps a lot.
Rob (Bad30th)
