C5 corvette Throttle position sensor help
The C5 drive by wire throttle position sensor is actually 2 sensors one from 0-5 volts and the other 5-0 volts.
Does anyone know if you unhook the sensor 2 wires should you still see TPS signal.
Maybe someone can do a test for me....They will need HPtuners or EFI live...this will not harm the wiring or computer.
At the TPS connector on the throttle body remove wires D,E,F which are Yellow with black strip, White, Pink. These control the internal #2 sensor.
Once they are removed hook up the scanner and turn the key on .....I am looking to see if you still get a TPS 0-100% signal. You will need to push the gas pedal to see if the TPS value changes in you scanner.
If no signal...start the car and do the same.....
I know this is a pain but maybe someone in the middle of a project could do this for me....it would be greatly appreciated...
Thanks.......oh please do not quote any GM service Manual info....I have the manual.......I need real live testing
THANKS Tom
Thanks Tom
Removing wires from pull to seat connectors requires having new terminals to crimp onto the wires to put it back together.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Speartech....do you know if I should still get a TPS signal with #2 sensor unhooked..
Here is why I ask....all codes and other problems aside......
I converted the drive by wire system to a cable system...so I have the old style TPS / throttle body.....I have Bigstuff3 running the engine.
I want to run the transmission off of the Stock computer.....so I am trying to get the TPS signal to the stock ECM....using #1 sensor input to the TAC unit.....I have managed to get every other signal I need to run the transmission..
QUESTION: The transmission shifts without the TPS hooked up.....but in HPTuners there are tables referencing TPS %......so I assume it needs to see signal to help with the shifting process..
Tom
