Throttle cracker table zeroed - I like it!
Result: the engine speed drops faster and my T56 shifts much better.
Is that a usual modification?
The engine is internally stock and the tranny should shift fine as it's programmed by GM. But somehow the engine speed was dropping too slow and shifting always took a moment. I was thining the tranny was shot and it was necessary to rebuild it. It doesn't seem to be necessary now
I know that cams with too much overlap need modifications in the throttle cracker table to avoid surge... but with a stock engine?
I always had to wait a moment until the RPM dropped allowing the gears to engage.
Maybe it's the tranny, maybe I have some vacuum leak... dunno. But now it shifts faster.
