Spark
Old Feb 12, 2007 | 10:44 PM
yobabiesdaddy2001's Avatar
Default Spark
What is the difference in the idle spark advance tables vs the main spark tables?
Old Feb 12, 2007 | 10:53 PM
SSpdDmon's Avatar
Based on the settings in your PCM, the car will use the idle tables instead of the main tables. Usually, it's based on less than 1.19% throttle and less than "x" mph. Autos usually have a low mph and manuals usually have an obsurdly high mph (255). Basically, it's off-throttle (idle) vs on-throttle timing.
Old Feb 12, 2007 | 11:20 PM
so, the main spark table is used when I am on the gas greater than 1.19% (or what ever I have mine set to) and idle spark is in control when ever I am not on the gas under both the throttle and mph enable figures?
Old Feb 13, 2007 | 10:11 AM
SSpdDmon's Avatar
Pretty much...
Old Feb 13, 2007 | 10:52 AM
you know it sounds that simple, but when logging the spark advance, it is hard to distinguish what table the pcm is working off of. I read that you should make all of the tables the same ( I think I will try and see if that works).
On your timing tables do you have a general area (group of cells) with one numeral (27 degrees) or do you have various degrees in a general area?
Old Feb 13, 2007 | 12:26 PM
SSpdDmon's Avatar
Again, log the approriate .pids and you can see which spark table is contributing what. If you look at just the final number, you can be playing a guessing game as to how the final spark was determined.
There are some spots on my timing table where a group of nearby cells all have the same values. This is mainly limited to WOT and off-throttle deceleration. The idea of doing this is, it ensures a specific value is commanded for a certian aspect of driving. When decelerating, I found that my car likes about 40* of timing under 2,000rpm. To keep it from jumping around, I have 40* of timing for 1,400-2,000rpm and anything less than .24 grams/cylinder. The effect is the appearance of a flat spot.
See below...cam is 232/238 with P&P 241 heads.
