VSS Question
Old Feb 13, 2007 | 07:46 AM
LS1MCSS's Avatar
Default VSS Question
The pcm on my car was originally programmed for a T56 VSS. I am switching to an automatic that doesn't/can't have a vss bolted directly to it. I can get an aftermarket vss that puts out 4000 ppm, digital signal, that will mount onto the orginal speedo cable ouput. What programming changes will have to be made to the pcm for this to work.
Old Feb 13, 2007 | 06:03 PM
LS1MCSS's Avatar
anyone??
Old Feb 13, 2007 | 10:48 PM
PunkNPonys's Avatar
Are you switching PCMs or staying with your stock one? If i am not mistaken it is just easier to get a PCM from a Auto car.
Old Feb 14, 2007 | 04:50 AM
LS1MCSS's Avatar
I would prefer to just use the one I have. I will have to get the car tuned when I get it running again anyway. I am also changing heads,cam, and intake.
Old Feb 14, 2007 | 12:04 PM
12secSS's Avatar
You answered your own question ...
In the PCM you can set the Pulse Per Mile to 4000 and you should be good. You do not need an "auto" PCM, they are the same. Just the clibration file that is flashed on there is different, it takes a meare 20 seconds to change that.
Old Feb 14, 2007 | 12:24 PM
LS1MCSS's Avatar
So, are you saying that the pcm can be tuned to use the 4000ppm digital vss?
Old Feb 14, 2007 | 06:22 PM
01WS6/tamu's Avatar
what type of auto are you running that you cannot setup an oem vss sensor on?
Old Feb 14, 2007 | 08:42 PM
LS1MCSS's Avatar
A 200-4R. It's got a lot better gear split than a 700R4 and can be built to hold a lot more horsepower than I will be making.
Old Feb 14, 2007 | 09:43 PM
01WS6/tamu's Avatar
Yeah you are a ok you can run a stock gm sender in it. Pull the tail housing off and get you a vss sender and reluctor ring for an 88-95 fullsize chevy pickup knock off the stock gear and then use a pipe thats larger than the output shaft and tap down the reluctor ring until it hits the notch the stock plastic gear was seated against. I did this on my monte when I ran a vortec 350 and a th350 tranny. It will work perfect as gm intended without any guessing.
Old Feb 15, 2007 | 12:03 PM
LS1MCSS's Avatar
Unfortunatly, I can't do that either. The 200-4R doesn't have a removable tail housing. The speedometer drive gear goes onto the governor. It's a poor design, but, at least it's the only tranny that chevy made that way. I may just go back to a mechanical speedo and not even run a vss. I found a post telling how to program the pcm without it.
Old Feb 15, 2007 | 12:12 PM
01WS6/tamu's Avatar
Ok I remeber now it's been a while since we have had one of those through the shop. Since you are not running an auto the vss is unnecessary anyhow. Good luck
