help my car is reading -39 degrees
Old Feb 17, 2007 | 12:11 PM
Travose21's Avatar
Default help my car is reading -39 degrees
my engine coolant temp senor circut high. my car is burning to much fuel. It is not the sensor because i replaced the sensor twice. what shall i do. I have 2002 heads on a 98 please help. the codes is p0118
Old Feb 17, 2007 | 12:13 PM
Travose21's Avatar
i needed the one with 3 wires not 2 but i got the one with the 3 wires and it is still doing the same thing. what shall i do
Old Feb 17, 2007 | 12:17 PM
brad8266's Avatar
Check your grounds first. If the drivers head ground on the back side connection isnt solid it will cause weird electrical issues.
Old Feb 17, 2007 | 12:22 PM
NoGamesLS1's Avatar
Hey bro try doing a search. I remeber reading about a guy who did a header install and had this problem. Im pretty sure that his ECT needed to be replaced. The sensor is on the driver side head.
Old Feb 17, 2007 | 12:37 PM
2xLS1's Avatar
http://www.gearchatter.com/viewtopic8760.php
Old Feb 17, 2007 | 12:44 PM
ChrisS@sdpc's Avatar
You can find some detailed instructions here. First thing, verify the wiring is good by jumping the circuit and verify the output through a scan tool. See steps 4 & 5 in the link above.
