LS2 TB on LS6 engine
Old Feb 20, 2007 | 04:06 PM
oange ss's Avatar
Default LS2 TB on LS6 engine
Does the LS2 throttle body use the same sensors/signal as an LS6 Vette TB ?
Old Feb 20, 2007 | 11:58 PM
oange ss's Avatar
anyone ?
Old Feb 22, 2007 | 07:01 AM
BOTTLE ROCKET's Avatar
If I understand your question; Yes it uses the same basic input wires, but you will have to buy an "adapter harness" to plug between your stock wiring harness and the LS2 TB.
Old Feb 22, 2007 | 07:58 AM
oange ss's Avatar
so the sensor plug in are different ? thanx
Old Feb 22, 2007 | 02:55 PM
The throttle body plug (END) is different on the LS2 than it is the LS1. When I swapped from a LS1 TB to a LS2 TB, I simpy purchased a plug and play harness addapter, pluged it in and fired it up.
Old Feb 22, 2007 | 03:49 PM
oange ss's Avatar
cool, thanx..did you get it from Casper ?
Old Feb 22, 2007 | 06:03 PM
I got mine from "king-pin" on another forum
