Wideband output to PCM?
The problem is I also want to use the FJO window switch capabilities. For this I need to use one of those outputs to trigger a relay for the n2o. So now I only have one analog output to stimulate both PCM inputs. What is the best way to solve this problem?
Should I split the single wideband output to both PCM inputs? Will that work?
Can I make the PCM use only one naarrowband input for both?
Any other ideas?
