Need to 'cheat' on Economy run
If you are going to make the run at noon, fill up early in the morning and squeeze that last ounce into the tank. Then just before everyone fills up to start, do it again. Make sure you have the column lock turned off and when possible shut off the engine and coast in neutral when possible. If it is going to be a highway run, try and have an hour run with cruise control at 60 and let the PCM lean out naturally before you get to the start.
Ben T.
I figured on inflating the heck out of the tires.. with nitrogen, and was even thinking of removing 2 or 3 of the brake calipars (put a block of wood between pads and hang the calipar off the rotor for less drag).
The added fuel resevoir would be good, but I'd have to measure the amount I'm putting in... might look a little suspicious if I come up with 150mpg!!!
i say kill the injectors b\c just killing the coil packs still means fuel is still flowing but killing the injectors will actually cause something like the gm dod setup also you can flip it back afterwards so it dosent seem cheezy.. finally you can program the car to ignore the 02sensors so it wont try and compensate for the bad 02 readings
Also keep in mind by hacking up the factory wiring harness you're inviting future electrical problems (unless you seal everything up very well)
Also I wouldn't personally try this at cruising speeds or under any load... decel already has DFCO so you could try adjusting that more aggressively... I honestly don't think cutting off 1/2 the injectors for short periods of time will help a whole lot though... the conditions under which you could do it safely are generally conditions where the injector pulsewidth is very short
Also if it's off for too long those 4 cylinders will have cooled down (DoD also prevents the valves from opening so it keeps the hot exhaust gas in there thus keeping the cylinders relatively warm and the same temp as the rest) ... could cause some running or hesitation issues after switching back on (just a guess as I've never tried it myself)
