weird power problem!
Old Feb 22, 2007 | 07:45 PM
nomorews6's Avatar
Default weird power problem!
my installer just finished installing the heads, cam, intake, pulley & exhaust and said if you turn the key on, the display will not show up, but if you bang around under the dash, it flickers. If you plug in a diagnostics scanner, the lights will stay on. It doesn't show any codes or anything.
help! any ideas? this is a 98 ls1
Old Feb 24, 2007 | 09:26 PM
OUTLAWZ RACING's Avatar
Vheck the ground on the heads on the driver side. Then check your fuses
Old Mar 18, 2007 | 04:06 PM
scottie dont's Avatar
i just had this problem. but it quit doin it after i put my starter in.
