PE Fuel Multiplier
Either your VE table or your MAF table, or both, is lying to the PCM. In order to get the result that you want, you now have your PE table lying to the PCM.
You got the result that you wanted, and only you know that it took a bunch of lies to get there.
I'd never do it that way, but that's just me. I tune both the VE and MAF tables so that I get exactly what I put in the PE table.
Take a look at your VE table. Does it look like this one?
It is the multiplier that sets your "Commanded air fuel ratio" You set this to what you want your airfuel to be, and adjust airflow to get the actual = commanded.
If you tuned the old way, raping the PE table, to get an actual airfuel ratio to not equal the actual, your not tuning the pcm properly.
Ryan
