Ls1, SD tune, TURBO, N20
Old Feb 26, 2007 | 11:20 AM
fastlt1's Avatar
Default Ls1, SD tune, TURBO, N20
I was thinking about buying a camaro that has LS1 swapped in since it doesn't use a MAF sensor I guess it uses a SD tune. Can I put a turbo kit on this. And My wet nos kit off my LT1. How would be best at tuning this?
Old Feb 26, 2007 | 12:29 PM
98turbls1's Avatar
What are the full details of the car?? From your statement I'm reading "I'm looking at a car that has an LS1 swapped in it and doesn't have a MAF...Can I turbo this car?" Is that a correct statement?? If so then yes you can turbo it...You just have to go to a 2 bar or higher Map sensor and have tuning software for it...I would go either turbo or Nitrous from the beginning, especially if you're tuning...Once you get really confident then I would add the other...Good luck
Old Feb 26, 2007 | 01:25 PM
fastlt1's Avatar
How is it running now with out a MAF sensor do you think?
Old Feb 26, 2007 | 02:30 PM
foff667's Avatar
LS1TECH Sponsor
most cars/trucks run just fine with no maf
Like already asked, full details on the car are the only way we can give you ANY insite.
Old Feb 26, 2007 | 08:17 PM
antivenom370ci's Avatar
I am running speed density. It has no maf. When I built it it had a Granetelli the tuner said it would be useless cold air tuned.
Old Feb 27, 2007 | 03:19 PM
fastlt1's Avatar
jeremy white from rogersville, tn owned the car
