starting problem 1998 Camaro
Idle dropped down to 500Rpm then stalled went to start again no crank no start,power is getting to 15amp fuse in junction box
Total list of mods: 6.0liter block, custom made JE pistons 8.5:1,6.125 eagle h beam rods. Dart Pro 1 heads 225cc h.sharp 1.7 rockers, Comp 248/242 .050 116LSA XER lobe Fast 90mm Tuned on speed density Has Stainless Steel piston rings so I dont want to idle to long so I don't glaze Cylendar walls very Critical The car ran great with Factory heads Just used a lot of oil,pulled from pcv system. so I switched to LS6 vallley cover,was initialy tuned by Hptuner Soon to be Twin turbo'd Breakin will be done N/A
Any way to make cruise control work w/Moser 9" F Body?
Any Help ON no start prob,things to check, schematics anything?
