Self Tuning?
Old Feb 28, 2007 | 01:18 PM
chadnol10's Avatar
Default Self Tuning?
How and what software do i need to self tune my car just for the air/fuel ratio? what is the easiest maybe even the cheapest way to go about this?
Old Feb 28, 2007 | 01:22 PM
brad8266's Avatar
https://ls1tech.com/forums/pcm-diagnostics-tuning/287094-read-me-first-tuning-docs-ve-maf-ses-lights-faqs-more-01-31-07-a.html
Doesnt anyone read stickies anymore?? Read that and then ask questions if you still have any. It will give you a basic understanding on the whole tuning thing and the different software. To tune WOT AFR only tune the PE table, it will do it, but in a false way IMO.
Old Feb 28, 2007 | 03:08 PM
SSpdDmon's Avatar
A WBO2 + a MAF translator is probably cheapest if all you want to do is adjust fueling. 2nd in line may be a handheld (like a Predator), but I don't know the extent of it's ability to adjust fueling. The model I had only adjusted PE (full-throttle). Newer versions have been released that adjust more, but I don't know if they're available for f-bodies.
Either way, it'll cost you a little more for a tuning suite. Then, you'll have endless tuning parameters at your finger tips.
Old Mar 1, 2007 | 08:30 PM
joecar's Avatar
Do you want to go cheap short-term or cheap long-term...?
Cheap long-term would be tuning software.
And as SSpdDmon said, tuning software is not that much more $ (you will want a wideband regardless); you won't regret it.
