Roaring during cold start
Old Mar 2, 2007 | 07:36 AM
onecamaro1's Avatar
Default Roaring during cold start
Everytime i get up in the morning, the car Roars when i crank it (its usually 30-40F oustide). This is rediculously loud at 5 am and I was wondering is there a way to calm this down. When the car has warmed up, it's not an issue. I'm using ls1 edit and Hp tuners. I can't figure this one out.
Old Mar 2, 2007 | 08:00 AM
SSpdDmon's Avatar
What are your desired idle rpms vs actual? Is it idling high?
Honestly, I think part of the problem is listed in your sig. LM2...yeah, that's not going to be quiet on a LT cam'd car - especially if you're running no cats.
Old Mar 2, 2007 | 09:56 AM
onecamaro1's Avatar
My desired is 850 and its spot on. But its like RRROOOOAAARRRRRRR!!!!!----> 850......hummmmmmmm.... When the car is warm and i crank it, it doesn't do that.
Old Mar 2, 2007 | 02:43 PM
wait4me's Avatar
sometimes it is caused by to much startup timing. Or if you force the min spark tables up too high, if you back it down some that issue should go away.
that or it is just mad at you for trying to start it durring the winter since it should be in its garage sleeping till spring.
Old Mar 2, 2007 | 02:47 PM
superchargedbandit's Avatar
It Is Hard To Use A Modded Car For A Every Day Driver
Old Mar 2, 2007 | 05:30 PM
94SS's Avatar
What's the numbers in this table look like Idle>Idle airflow>IAC park position airflow. You can try lowering them if they are really high.
Old Mar 2, 2007 | 10:43 PM
SSpdDmon's Avatar
How does that relate to anything? My software describes the IAC park position as the spot where the IAC sits or "parks" itself at key-on and key-off times in relation to intake air temps (even though I really think it's coolant temps). So, if you find the car running on a little after you turn off the ignition, I would think lowering that table might help. Or, if you have to give it some gas to get it to start, increasing that table might help. Other than that...I don't know how it would apply.
