MAP sensor bad during tuning
Old Mar 10, 2007 | 06:41 PM
AutomagicLS1's Avatar
Default MAP sensor bad during tuning
I had a MAP sensor come loose during the dyno run (FAST intake) and caused some problems. We used some gooey **** to hold it in for the dyno. later that night we pulled the intake off cleaned off the area where the sensor goes into and bought a new one from the stealership. Everything is clean and sealed up now. Would the new sensor effect the way the car runs after the tune? Im trying to figure out if its the sensor messing with the tune or extremely tight gapped plugs that I was going to use for the spray and I need to get a hotter plug or change plug gap. Any thoughts?
Old Mar 11, 2007 | 10:47 AM
Doc's Avatar
Doc
What is wrong with the car? The dyno was for WOT tuning I take it? Is the problem drivability or do you think it is down on power up top? What kind of plugs are you talking about? How much of a hit are you talking about? Wet, Dry?
