Tune for power
Being a 99, I think you'd be lucky to find more than 8 in timing, but it may like a slightly leaner AFR.... Point being, after that pull, it's not a sure thing to see past 10rwhp. This car is an exception to the rule for the MOST part though.
... until he drove it and part throttle/response was much improved.
Rich will allow/require higher, or more advanced timing because the denser fuel mixture has a slower burn rate. Therefore, finding the optimal point of ignition will require the spark to fire sooner. So, in a sense you're retarding the timing indirectly by running a richer mixture.
The truth is, you want the optimal mixture and the optimal timing together. To get there, you need a WBO2 and a dyno...plain and simple.
Thats what my guy was doing he kept dropping AFR 14 to 13 to 12 etc which I thought was getting richer. I could see the AFR on the dyno screen but he wouldnt give me any timing specs. He said WOT timing didnt actually show on the screen but he could figure it out or calculate it. He was using HPtuners.
Sometimes an aftermarket MAF turns out to be kinda lean at WOT, but they end up needing recalibrating anyways.
Most of the gains on stock or bolt on cars average 15-20 RWHP pretty consistently.
I've had to work hard for 14 or 15 on some, and then others will nail 20 or more real easily. I have seen gains of up to 25 on header cars.
I thought afr in 11's was rich and 13/14 headed toward lean?
Your tuner should be willing to show you what he has done. At least show you something like the timing table.
Dyno says he started at 13.0 to 13.7 low to high rpm.
Finished with 12.4 to 12.9 low to high rpm.
He said he made some timing changes but didnt reveal any timing specs. He did say it didnt knock anymore but I dont know if the increased richness stopped the knock or if he just retarded total timing???
Thanks for the feedback it def helps. Hey your 02 timing question was that with torque management active or deleted?
I only ran 50% torque management on that car because of the stall. But, that shouldn't matter during WOT...just during WOT upshifts.
Ok, so from what i've gathered so far in this thread, I shouldn't gain much from the tune since I was already pretty lean. However, my maf might have been throwing off the afr, correct? If I go in and dyno the same ~332 with the same 13.05 afr, what should i do to find more power? With all my mods I should be making atleast 340, I think we can all agree on that.
Thanks guys...
All depends on the vehicle.
Stock focus picked up 4 fwhp, and a stock 6.0 diesel, will pick up 150 rwhp.
most lsx gain about 10-15 rwhp on average, some only pickup 5-7
Ryan
[good question]
