ENG SEN fuse....
Anyone have any ideas about that?
Have you pulled ALL the power to your self-installed accessories?
From what I've read, the car would still start and run without an ENG SEN fuse....but my car won't do anything, hence the reason I'm thinking(hoping) it's the IGN fuse.
Also, I just realized that the radio does not work when the car is in the start position. Everything seems to go dead when I have the key in the start position, however, the horn will still work. It appears that all accessories work when the key is in the ACC position.
Now I need to know how to check the resistance in my key and how to bypass the VATS.
Is this the security system?
I'm gonna get my spare key tonight and try that out. If that doesn't work, I'm gonna try and bypass the VATS and see if it's a faulty lock cylinder. I've read several threads describing the exact same thing as me and it turned out to be the VATS.
I unplugged the key cylinder from the VATS and put the key in the ignition. The key cylinder side read exactly what the key pellet read, so I'm sure that's not the problem. I plugged it back into the VATS and then took a reading from the VATS side and it still read 11.69.
Power still shuts down when I just turn the key to the ON position, or w/e position it is just prior to starting the car. Obviously I'm getting power to the IGN relay though, because all the fuses still have power to them when the key is in the ON position. However, the fuse from the inside fuse panel is still dead, the IGN one.
I just want my car to start....
