how could you reset the pcm?
Old Mar 27, 2007 | 06:07 PM
senicalj4579's Avatar
Default how could you reset the pcm?
can you do this by disconecting the batt. and unpluging alot of wire harnesses?
Old Mar 27, 2007 | 06:14 PM
horist's Avatar
that'll clear the short term memory (fuel trims, ses lights etc...) if that's what you're looking for (also if you remove the PCM BAT and PCM IGN fuses w/the key on the on position and wait 30 seconds should also do the trick)
if you want to reset the PCM tune however, only way to do so is with a tuner (HPT, EFI, LS1 Edit, Tunercat, or OEM utilities such as a TechII)
Old Mar 27, 2007 | 06:17 PM
well i did and ls6 intake swap and i unplugged needed wire harnesses and all that to install the intake. wonding if its possible i may have reset some things because i'm getting some codes on my car now.
Old Mar 27, 2007 | 06:19 PM
brad8266's Avatar
Remove the PCM bat and PCM IGN fuses with your key in the "on" position, that will clear your codes and reset the PCM.
Old Mar 27, 2007 | 08:06 PM
would that also clear a tune from a handheld?
Old Mar 27, 2007 | 08:12 PM
brad8266's Avatar
No, only a reflash will clear the tune.
