timing advance
Old Apr 4, 2007 | 07:02 PM
ls1pwrdss's Avatar
Default timing advance
if i wanted to add 2 degrees to my timing with hp tunners would i go under high octane table and add 2 to all parameters
Old Apr 4, 2007 | 07:10 PM
brad8266's Avatar
Yes if you want to add 2 degrees to the open throttle positions then yeah add 2 to the entire high octane tables. If you want to add 2 at idle you need to change base spark in park table and you might as well add 2 to the base spark in drive table.
Old Apr 4, 2007 | 09:09 PM
SSpdDmon's Avatar
Originally Posted by brad8266
yes if you want to add 2 degrees to the open throttle positions then yeah add 2 to the entire high octane tables. If you want to *** 2 at idle you need to change base spark in park table and you wight as well add 2 to the base spark in driver table.
Is this your Ace Ventura impression or Elmer Fudd?
Old Apr 4, 2007 | 09:15 PM
brad8266's Avatar
Elmer Fudd FTW!!! I just noticed that, lol. edited
