Ignition slope?
Old Apr 6, 2007 | 12:09 AM
Jrp1978's Avatar
Default Injector slope?
What is ignition slope and what does it do . Its on my predetor , but i have not messed with it. Also i still have a still idle problem it slowly raises and lowers about 350 rps sometime no all the time!
Old Apr 6, 2007 | 06:48 AM
brad8266's Avatar
I would imagine it raises your spark advance. Im not 100% sure though since I never used a Predator.
Old Apr 6, 2007 | 09:52 AM
Jrp1978's Avatar
Default shooooooot
i meant to say injecter slop! Hey bradster i got her tuned the price was high becuase i bought a predetor in case i change gears or little thing . 386.1 hp and tq was 366.5
Anyway injector slope is what i am after
Old Apr 6, 2007 | 03:46 PM
06MonteSS's Avatar
LS1Tech Sponsor
injector slope tells your ECM that your injectors are a different size and to spray more/less fuel. You use that parameter adjustment to get your fueling (long term fuel trim) in line at normal cruise/driving.
if you go NEGATIVE on injector slope, you're telling the ECM that your injectors are SMALLER and to spray MORE fuel.
if you go POSITIVE on injector slope, you're telling the ECM that your injectors are BIGGER and to spray LESS fuel.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
