fast idle problem
Old Apr 7, 2007 | 07:36 AM
99sixspeed's Avatar
Default fast idle problem
car idles at 1500 rpm help
the problem started all at once, always ran fine then one day when i tried to start the car it started up and ran for about 5 seconds then the check engine light came on and it died. tried several time before it would run , then it ran fine , but know it idles at 1500 rpm's???? the only code it set was alternator code , can't recall exactly was it said though???
the only thing that was changed was i had a clutch master cylinder put on? and a skip shift ellimator jumper
Old Apr 7, 2007 | 09:42 AM
txhorns281's Avatar
take your foot off the gas? lol
Gonna need at least a little, but prefer alot more detail that this if you want some input
Old Apr 7, 2007 | 11:14 AM
Jrp1978's Avatar
Default Hmm
I am no expert ......... that is why i come here , but when did this start just outta the blue!
Vac leak
tps sensor
ect sensor
is it throwing any codes
have you made any changes to the car
Old Apr 7, 2007 | 09:49 PM
faster_n_you98's Avatar
disconnect the battery for a minute and start it again. mine did that when my battery was dead. dunno why. hope it helps.
