help with PE settings for track
heads and cam, 4000 stall. leaving off the line around 2500-3000 rpms.
any ideas?
PE Enable MAp: currently 15kpa
PE Delay RPM: currently 4000 rpm
PE Enable TPS: currently around 64%
have seen people set a higher MAp value and lower TPS value.
I'd assume you dont want to go into PE while sitting at the line brake stalling it up. I guess the RPM needs to be a little higher than the stalled rpm. whihc method should i do?
using HP tuners. thansk guys
what is a good MAp and MAP HYST value if I run it like this? leave it low like 15kpa and 6kpa HYST. thanks
FWIW guys I've talked to Chris about it so we can make the definition a little clearer on the pe delay stuff, but for the most part the delay rpm has very little affect on things for the most part. IE many stock calibrations have it set to 5500 rpms...that doesnt mean you won't enter pe mode until 5500+ rpms...it just means that if PE hasnt already been engaged by 5500 rpms because of the delay timer(which isnt active in most applications) it will then activate PE mode.
For the record I usually just set the delay's to 0 & use the tps vs rpm as my activator.
