car only runs for 10 sec
Old Apr 23, 2007 | 03:51 PM
chris20516's Avatar
Default car only runs for 10 sec
i have a 2000 z28 and when i start the car it dies 10 sec. later.
I have checked fuel pressure and it appears to be good. so i put a scanner on the car and it threw a code saying something about the theft deterent system.
is their any way i can bypass this?
thanks
Old Apr 23, 2007 | 04:05 PM
TAQuickness's Avatar
If the VAT's is what is killing it, then yes you can bybass it. You need to get someone with EFILive or HPT to fix you up.
Old Apr 23, 2007 | 04:40 PM
chris20516's Avatar
Default car starts the dies
i had the bcm and the whole ignition.
Old Apr 23, 2007 | 06:44 PM
wait4me's Avatar
The pcm will need to be programmed more than likely. Even after you get it running it will throw lots of codes unless you set them up correctly..
Old Apr 23, 2007 | 08:12 PM
sreve's Avatar
tuning is best,this will work.
http://shbox.com/1/vats_bypass.jpg
wire colors the same on the '00. at the bcm d7 and c2 is where you wire the resistor. there are some good reads on vats here
http://shbox.com/1/4th_gen_tech1.html
Old Apr 23, 2007 | 10:42 PM
chris20516's Avatar
Default car is running!!
got the car running!! i just unplugged the wires and plugged them back in on the bcm. so far so good! thanks for all the help
