program to buy ?
Old Apr 23, 2007 | 05:23 PM
chris20516's Avatar
Default program to buy ?
what program does every one prefer? and why?
Old Apr 23, 2007 | 05:27 PM
foff667's Avatar
LS1TECH Sponsor
Here's a good starting point https://ls1tech.com/forums/pcm-diagnostics-tuning/368718-read-me-best-ls1-tuning-software-best-scanner-best-handheld.html
Old Apr 23, 2007 | 06:08 PM
fil131's Avatar
I know that hptuners is probably the favored, but its not the only one, I really purchased LS1 Edit because of the deal I got on it with unlimited VINs for all 97-03 camaros/firebirds/vettes with LS1 and LS6 engines. If you learn your program and put it to use then it will work for you, and do your car lots of good.
Sometimes a good deal is the buying factor, not to knock HPTuners at all, I do plan on purchasing their ford and dodge tuners later.
Just my 2 cents, if money is your factor look for the best deal, new or used. If ease of use and readability is your factor look for a tool that gives you that. research research research, make an informed decision and you will find the tool that works best for you.
