reading 02 trough pcm
Old Apr 23, 2007 | 11:46 PM
bird2002's Avatar
Default reading 02 trough pcm
Im very interested in getting a hyperpac for many reasons, one of them being that it has an air fuel read out. (not the only reason y i want it) However i was told that you are not able to get an air to fuel read out from the pcm at wot because the computer goes into a open or closed set loop. Basically the question is will i get an accurate reading of air to fuel ratio at wot?? Are any of the computer programs able to??
Old Apr 24, 2007 | 08:11 AM
wait4me's Avatar
EFILive will show you alot more than that other thing you want to use.
You can use your laptop instead of that device.
Do a search for WideBand 02. That will explain why you dont get accurate air/fuel ratio using a narrowband stock o2 system.
