Need Help Tps, Map, Map/VAP AFU???
Old Apr 24, 2007 | 06:01 PM
shooter's Avatar
Default Need Help Tps, Map, Map/VAP AFU???
Ok so here is the problem, I had to put my car back to stock again because it was acting up big time. She's running like a champ, so I would have to say it's a tune? I don't know about other A4's but mine didn't like the 90/90 at all without a tune anyway. I do have one small problem: for some reason or another ASR isn't engaged nor will it engage. Seems like I disengaged the ASR while I was doing the swap!!! Oh and yes it was working fine before I started all this stuff. And It's still running crappy so I had the codes read out and my map, map/vap and TPS are all F&^%ed up do I need new one just I swapping it to a 90/90 and back an LS6 set-up???
Thank-you in advance for the help!!!
Old Apr 25, 2007 | 03:51 PM
SIC LSX's Avatar
bump....
