plug question.
Old May 3, 2007 | 01:58 AM
BigBenz's Avatar
Default plug question.
I got me some tr6s and i put about 100 miles on them. i installed a d1sc( none of the miles are under boost) Going to a tuner this weekend another 40 miles. My question is will the plugs be good after i drive to the tuner? i had people say that these plugs will foul easy. I pulled the second plug on the driver side to take a look and it looks just fine a little black on the white nipple thing leading to the "L" Nothing major. Should i bring a extra set of plugs? I dont see why these would be bad. I made about 7 high rmp passes (no boost just blowing on the ground) to make sure the belts line up on the Blower. Everythng seems fine. anyone had these plugs foul real quick? Should i check the rest of the plugs? i dont want any problems at the dyno.
i also installed pacesetter LTs and a ATI damper. thats it.
Old May 3, 2007 | 05:20 AM
LS1_TA_2002's Avatar
A few high speed runs on the dyno will clean 'em up. They're still new.
