narrowband O2 readings
Old May 3, 2007 | 01:19 PM
rbrcka's Avatar
Default narrowband O2 readings
I realize that narrowband's are only accurate for the 14.7:1 "narrow" band and then read rich or lean from that point. But on a scanner which way does the O2 read for each direction. Like if I was doing a WOT pull and the O2 outputs where 900 vs 1000. Which way is going leaner?
Old May 3, 2007 | 02:36 PM
Caspernicus's Avatar
guess the stickies aren't big enough......
https://ls1tech.com/forums/pcm-diagnostics-tuning/287094-read-me-first-tuning-docs-ve-maf-ses-lights-faqs-more-01-31-07-a.html
-click the first link under 'Learning to tune'
-Then click the first link in the new window. Look at page 4 of
the word document.
Old May 3, 2007 | 02:49 PM
06MonteSS's Avatar
LS1Tech Sponsor
the higher the number, the richer it is...
the lower the number, the leaner it is...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old May 3, 2007 | 03:22 PM
rbrcka's Avatar
Thanks! I was thinking it was the other way around. For some reason I was thinking leaner/hotter more voltage. Makes me feel better for what I've seen on my logs.
