Help Translate O2 Sensor Codes P0138 P0133 P0153
Old May 8, 2007 | 10:36 AM
assassinz28's Avatar
Default Help Translate O2 Sensor Codes P0138 P0133 P0153
p0138 P0133 P0153
Hello I Was Driving My Car Sunday Night Perfectly Nothing Wrong The Only Thing I Noticed When I Got To The Stoplight The Ses Light Came On And When I Tried To Take Off The Car Felt Weird Like It Would Go Then I Would Not If I Try Pushing The Gas More It Would Not Do Anything Then I Let Of The Gas And Barely Tap It To Keep Going Then It Would Keep Going But When I Try To Press It To Accelarete Fast It Would Feel Like It Wanted To Die I Went To Auto Zone It Gave Me All Those Codes P0138 P0133 P0153 First Of All What Is Bank 1 Sensor 1 Bank 1 Sensor 2 Help Me Interpret This Stupid Codes Which Sensor Is Which But Anyway Ihave A 98 Z28 With Pacesetters Long Tubes Ory Slp Loudmouth Exhaust In The Front I Have Regular O2 With Extensions And Back I Have O2 Simmulators I Don't See Anything Weird Underneath Anyway I Went Bought Brand New Front O2 Sensors Put Them In Than It Does The Same Thing Took It To Auto Zone To Have To Code Cleard Runs Fine Than It Did It Again Than All The Sudden It Stops Doing It And I Drove The Car 130 Miles Today And Has Not Done It Again And The Ses Light Is Off Do You Think Is Fixed Or You Think It Will Come Back And Help Me With Those Codes Interpreting Wich Sensor Is Which And Do You Thin'k It Could Be Fuel Problem Since I Do Have A Programmer And Selected The Non Rfg Tune Could That Have Anything To Do With It Please Help
OH I ALSO HAVE THE GRANATELLY MAF ENDS AND THE CAR IDLES PERFECTLY JUST WHEN I GIVE IT GAS ON DRIVE IS WHEN IT DOES IT
Old May 8, 2007 | 12:02 PM
Please Somebody Help Me
Old May 8, 2007 | 01:47 PM
2001NBMZ28's Avatar
P0138 is Bank 1, Sensor 2
P0133 is Bank 1, Sensor 1
P0153 is Bank 2, Sensor 1
Bank 1 is drivers side, Bank 2 is passenger side. Sensor 1 is precat sensor, Sensor 2 is postcat sensor.
You mentioned NON RFG tune and an aftermarket MAF. Are you using an HPP3 tune? If so take the tune out of the car if it starts acting up again, pretty sure HPP3 assumes you're using the stock MAF.
Hope this helps...
Old May 8, 2007 | 03:12 PM
It Has Maf Ends Same Stock Sensor I Just Bought The Ends Will It Make A Difference
