Coolant Temp on LS1 Car
Old May 11, 2007 | 02:59 AM
the_merv's Avatar
Veteran: Air Force
Default Coolant Temp on LS1 Car
What wire on a LS1 F Car does the Colant Temp Guage get it's signal from? I have it traced in the Harness from the Sensor, but which wire actually sends the Signal to the Guage..how is the Guage wired?
Old May 11, 2007 | 10:37 AM
Doc's Avatar
Doc
Depends on what year of pcm/harness you are running? 97/98 has a wire going from the sensor to the cluster. 99+up routes the signal from the sensor to the pcm and the pcm sends the info on the serial data line to the cluster.
Old May 11, 2007 | 04:52 PM
the_merv's Avatar
Veteran: Air Force
Is the Serial Data Line the Green one that goes to the Diagnostic port as well, cause that is the only one there is..
Old May 11, 2007 | 05:24 PM
Doc's Avatar
Doc
Nope, on the 98/99+up Fcar, in vehicle datalink connectors, it is the purple wire, pin 2.
