Tuning issue or vaccum leak?
Old May 14, 2007 | 05:02 PM
KurtRardin's Avatar
Veteran: Marine Corps
Default Tuning issue or vaccum leak?
So I installed a hotcam about 800 miles ago. I am experimenting with my tuners abilities all the time, and I will be getting a wideband soon. One problem though... After the car is nice and warm, when I go to turn the Air Conditioning on it dies. It will not idle without some gas pedal with the A/C on. Cruizing down the road is fine, but you better shift quick because if it tries to idle then it will die. Does this sound like a tuning issue?...or a vaccum leak??
Old May 14, 2007 | 05:50 PM
hpmotorsports's Avatar
what tuner do you have
Old May 14, 2007 | 06:28 PM
VinceTrifecta's Avatar
Check your IAC counts and throttle blade adjustment. Also, you may need to increase your IAC offset for A/C anticipate vs A/C pressure. I had the same problem when I did an LT4 conversion w/ HOT cam in my Impala SS. Increasing the numbers in this table solved the problem.
Old May 19, 2007 | 02:10 AM
KurtRardin's Avatar
Okay. I got it ironed out. I've got a vinci tuner BTW...very awesome tool. Now she drives like a dream and the A/C works fine. Turns out the car just needed about a weeks worth of heat cycles to learn a new idle, both with the A/C on and off.
Old May 19, 2007 | 08:55 AM
Doc's Avatar
Doc
Vince is right. I bet if you pull the battery your Learned Idle will reset. Idle learning is a bit pushy for my taste. I would nail down the Desired Airflow with Idle learning turned off.
