WOW!!! Turned off MAF
Old May 16, 2007 | 08:39 AM
99ChargedFRC's Avatar
Default WOW!!! Turned off MAF
Last night I decided instead of paying someone to tune my car I was going to dive into it and read as much as possible. I have read so many posts on here I am dizzy!
I have been logging my car and it has been lean so far across the board on my wideband. Last night I turned off the MAF and its rich across the board. I finally think I found my weak link. I think the MAF is calibrated wrong. I am going to tune Open Loop SD and then scale the MAF. Its just weird, the thing was idling at 17:1 in MAF and then SD its 12:1. Could this mean the MAF is bad?
Old May 16, 2007 | 08:51 AM
Black02SS's Avatar
No it means the tune is out of wack.
Old May 16, 2007 | 09:17 AM
I figured thats all it meant. So basically the MAF is going to need to be scaled down??? What happened to Marcin's spreadsheet?
Old May 16, 2007 | 10:39 AM
ZL1Killa's Avatar
scaled up. you don't need Marcin's Spreadsheet.. i did it on my car in about 20min and the MAF was fine.
scaling the MAF up means more fuel
scaling the MAF down means less fuel.
its just like the VE table, you add numbers to it, you add fuel,
take away, you lose fuel
Old May 16, 2007 | 12:51 PM
RedHardSupra's Avatar
you dont need marcin's spreadsheet because it was made for hpt 1.x where making custom histograms was a no-no.
you do need marcin's spreadsheet if you want to combine data from multiple logs, something that hpt is still not able to do...
anyway, new MAF spreasheet with a LOT of new functionality is coming...early summer i'm guessing.
Old May 16, 2007 | 03:03 PM
SSpdDmon's Avatar
Make sure it's EFI Live compatible too.
