Turning off ABS light
Old May 18, 2007 | 05:14 PM
96blkformula's Avatar
Default Turning off ABS light
Ok my friend has EFI live and i was thinking about taking out my abs module well if i do that the abs light will be on. I was wondering if we use EFI live will we be able to turn off the light on my dash so post up if u know thanks
Old May 18, 2007 | 06:44 PM
caliswangin916's Avatar
from all my reading on here. NO.
abs is in the bcm not pcm. kill the bulb.
Old May 18, 2007 | 10:01 PM
MeentSS02's Avatar
Kleeborp the Moderator™
No can do (as already stated)...you'll need to remove the bulb.
Old May 19, 2007 | 12:18 AM
alright thanks guys thats what i need to know!
Old May 19, 2007 | 10:06 PM
thecorrectformula's Avatar
I know i'm gonna sound like a mother here but you should leave the abs installed and working. I rear ended a chevy tracker about two weeks ago in my formula. because my abs didn't work. I was only doing about 30 when I hit the brakes. My wheels locked up so I couldn't steer or anything. If I would've had my abs I'm pretty sure I could've avoided hit the other vehicle. It causes 4300 worth of damage to my car even though I got slowed down to about 15 when I hit the car.
