p1133 p1153
Old May 20, 2007 | 08:28 PM
SS4Luck's Avatar
Default p1133 p1153
after i switch my plugs and wires yesterday these codes popped up tday
what are they exactly?
Old May 21, 2007 | 09:22 AM
ChrisS@sdpc's Avatar
Your O2's aren't switching enough for the PCM to be happy. You can find specific details here. Do a search here, and you will find lots of info. The errors are very common with headers. Since you just changed plugs and wires, I would first check to make sure all of the physical connections are good and/or pull all the plugs to make sure they are all firing.
Old May 21, 2007 | 12:32 PM
98Camarod's Avatar
You wouldn't happen to have BOSCH 13111's would you?
Old May 21, 2007 | 12:53 PM
ZL1Killa's Avatar
just turn the codes off...the car runs fine without them. mine has had both of them turned off for 2+yrs
my car showed those codes on the stock 02's
Old May 21, 2007 | 05:34 PM
SS4Luck's Avatar
yea i have 13111s
Old May 21, 2007 | 09:10 PM
98Camarod's Avatar
There is a whole big thread on how those switch slow on certain cars. Mine was one of them so I got a set of stockers and extensions.
