Another Question on TPS sensor output wire?
Old May 23, 2007 | 11:16 PM
SSDoubleK's Avatar
Default Another Question on TPS sensor output wire?
On my 98SS the output wire was blue, on the 2000 is it the Blue wire? I had attached to this wire and the car did not want to Idle correctly? I was assuming the blue wire was also the ouput wire on my 2000, I do realize the wiring is different on the 99-02, that's why I'm asking this, archives only picked up one post on this subject directly. THanx for your intput.
Old May 23, 2007 | 11:22 PM
waterbug1999's Avatar
If you got a multi-meter, you could easily check the conductivity just to make sure.
Old May 23, 2007 | 11:37 PM
SSDoubleK's Avatar
Alright, I figured I could do that, just was hoping for a clear cut answer from another member who may of had this problem before, and the wire color for the output wire. Thanx for your response.
Old May 23, 2007 | 11:43 PM
I did the same thing when hooking up my WOT for my window switch. I just dont remember what wire it was and I am at work so I cant go check for ya...
Old May 23, 2007 | 11:49 PM
2xLS1's Avatar
What did you attach to the wire? Blue is the variable TPS output on all 98-02 fbodies.
