tuning needed when Change CAm
Old May 28, 2007 | 04:25 PM
tee-boy's Avatar
Default tuning needed when Change CAm
Q1. With a MAF based system, is there really a need to get a tune when you swap a stock cam w/ a more agressive cam? It seems to me that the PCM will recognize the VE differences of the new cam based on input from the MAF.
Q2. Same question as before except cam/head change.
On a similar note, what is the purpose of a VE table in a MAF system?
Old May 28, 2007 | 05:25 PM
foff667's Avatar
LS1TECH Sponsor
depending on how large the cam is & its application a tune might not be necessary but to get the most out of a given combo it would be highly recommended. The maf/o2's can compensate a good amount at part throttle but not WOT.
same as above.
as a sanity check while the maf is functioning properly & as a main source of fueling if the maf fails.
