Not going into closed loop
Only DTC code im getting is MALF33: MAP high which started appearing after I adjusted my valve lash. Unfortunately I don't have a wideband. It's interesting you say that though becaue I got a dynotune with a fuel pump that was crapping out at 4800rpm and it was tuned partially. I have not had the chance to bring it back after I installed my racetronix fuel pump kit. All my logs have been after the racetronix pump install.
