Quick AFR question
Old Jun 11, 2007 | 05:25 PM
Blades's Avatar
Default Quick AFR question
richest value for my mods=??? @ peak torque... extra points if you can guestimate my peak torque. My cmd'd afr = my afr..
Also. I guess im going to extend the question.. When my converter locks up on the highway and I just barely tap the gas I command a stupid rich afr.. Closed loop does not behave like this.. It always commands 14.7 until WOT. I have scaled back IVT vs MAP (open loop fueling). So.... should I scale it back a little more to behave like open loop? Sometimes I'm seeing cmd'd 14.10 in situations that should not warrant a richer fuel mixture. 13.90 when the ac is on.
Old Jun 11, 2007 | 05:35 PM
foff667's Avatar
LS1TECH Sponsor
most aim from 12.2-13.0:1 at peak tq in an NA application.
Old Jun 11, 2007 | 06:07 PM
Blades's Avatar
Thats a rather large variation. Could you be more specific. I know that being richer at peak torque is "better".. 12.6 sound like a good #? Its like this until redline 12.6->12.65->12.7->12.8
Old Jun 11, 2007 | 06:46 PM
ZL1Killa's Avatar
on my car i have seen 12.6 down low up to a 13.2 up high it liked
Old Jun 12, 2007 | 02:12 AM
Blades's Avatar
I hope you are referring to when it was N/A!! Please.. chime in with more suggestions. Right now I am peaking at 12.77..... What RPM range is considered up top? 5500+?
