HP Tuners question, Is there anything to be gained...
I am new to HPT and have been using it so far with decent success. I have two areas I would like to improve upon, one being the part throttlw map and WOT map.
I did not get the WB option so the WOT map is out of the question until I get the headers and go for a tune then, but the part throttle map should still be able to be tweaked.
Who on here has done this and can guide me and maybe explain some of the faucets of the HPt program?
Read the stickies for basic tuning how-to. Here's a tip as well: put your screen back in your MAF until you're ready to have it calibrated.
I have a 2006 GTO now...
Side note as well, once you remove those screens they are for the most part destroyed almost everytime. I have never had any issue running without them in amy of my cars so I always pull them right off of the bat. I dont buy into the straightening the airflow thing. If you look at a wing or foil that also straightens airflow you will see at the end of the edge the air gets very turbulent, same thing I would assume happens on the MAF screen.
The screen is nothing more than a least restrictable as possible safety measure to keep debris in a worst case senario from enter the intake tract.
Hit the GTO forums and find out which input you can feed the wideband back through.
