SVO injector?
Old May 4, 2003 | 05:53 PM
99 TA's Avatar
Default SVO injector?
I am going to be putting SVO 30lb injectors into my 1999 TA. With edit do I just need to change the injector scaling or do I need to also change the offset too?
Old May 4, 2003 | 07:11 PM
red ws6 99's Avatar
Default Re: SVO injector?
I would change both the injectors are slightly faster than stock. This is from the LT1 pcm for those injectors. You can use Chris Bennight program to get a Ls1 table. The stock offset should be close enough that you wont have any problems, if you dont feel like tinkering with the file. I had to get curve for the msd 50 lb injectors because they are almost twice as slow as stock, which made idle tuning not fun.
Volts 12.4 12.8 13.2 13.6 14
MS 0.59 0.56 0.52 0.52 0.49
Gary
Old May 4, 2003 | 09:07 PM
99 TA's Avatar
So should I use the second table from here? I think his other example for injector scaling used the 30lb injectors so I would think this example uses the same. I'm not real good with all the math and other stuff. I just want to make sure it's right and I don't mess anything up. Thanks in advance for any help.
Adam
