M6 Idle Question
Old May 4, 2003 | 06:44 PM
1998_Z_6_Speed's Avatar
Default M6 Idle Question
I have a 6 speed 1998 Z28 that with a descreened MAF, a 160 degree stat, and TR6 gapped at 0.050 (100 shot dry).
My car always idles at 1,000 RPM, is this normal?
Old May 4, 2003 | 06:58 PM
wrencher's Avatar
wrencher
Default Re: M6 Idle Question
No ..., that's a little high. You got a vacuum leak or something misadjusted at t/body. Do you have something to scan PCM with & check the iac counts??
Old May 4, 2003 | 08:33 PM
No I don't have anything to scan with. I've owned the car since last July and always thought the idle was high.
My thought was, is it possible since I never seems to get above 165 degrees that idling at 1000 is normal?
Old May 4, 2003 | 11:35 PM
Cal's Avatar
Cal
No I don't think that's your problem. 165 is about what mine runs at in the winter with the 160 deg T-stat, and mine idles at 800. Try spraying carb cleaner on the joints and see if that speeds up the idle.
