Cold Lockup Table **easy Q**
Old Jun 14, 2007 | 10:44 AM
Jpr5690's Avatar
Default Cold Lockup Table **easy Q**
Is There A Way I Can Tell My Tranny Not To Lockup If It Is Under A Certain Tranny Temp?
Right Now I Only See Lockup Vs Mph But Some Have Said You Can Have Your Tranny Set To Not Lockup When Its Cold
Is This True?
Old Jun 14, 2007 | 10:54 AM
performabuilt's Avatar
LS1Tech Sponsor
I am not sure about looking at the setting but I do know the engine temp must get to aprox 135 to 145 degrees before the PCM will enable lockup .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 14, 2007 | 11:10 AM
Ragtop 99's Avatar
I expected to see it in HPT, but did not find it after a quick look.
I'll move this to PCM section. What software are you using?
Old Jun 14, 2007 | 12:49 PM
LS1curious's Avatar
TCC enable temps is a constant. Its not a table. there will be a Min enable Tempature.
Old Jun 14, 2007 | 10:39 PM
Jpr5690's Avatar
Hp Tuners...
And Yes I Know It Will Be A Constsnt But Can I Adjust This Minimum Limit
Old Jun 20, 2007 | 07:41 AM
Jpr5690's Avatar
Guess Not?
