Speed density????
Old Jun 22, 2007 | 05:18 PM
Black02SLPSS's Avatar
Default Speed density????
Ok for starters im a complete noob when it comes to this tuning business. So how does a speed density tune work and able to delete the MAF sensor?
Old Jun 22, 2007 | 05:29 PM
foff667's Avatar
LS1TECH Sponsor
by unplugging your MAF sensor your in Speed density mode which rely's mainly on your VE table which is what would be tuned in SD mode.
Old Jun 22, 2007 | 05:39 PM
waterbug1999's Avatar
Whats the pros and cons?
Old Jun 22, 2007 | 06:25 PM
foff667's Avatar
LS1TECH Sponsor
comon man your no newb...stickies are your friend around here
https://ls1tech.com/forums/pcm-diagnostics-tuning/509481-advantages-disadvantages-sd.html
Old Jun 22, 2007 | 07:53 PM
https://ls1tech.com/forums/showthread.php?t=509481
LOL... I just have not read up on it and I have been hearing more and more about it.
Old Jun 23, 2007 | 01:05 AM
Doc's Avatar
Doc
Yeah I've been hearing about this movie called "Star Wars?" Could you guys tell me about it too?
Old Jun 23, 2007 | 05:06 PM
Rob's Avatar
Rob
Something about a galaxy far, far away...
Old Jun 24, 2007 | 03:03 PM
Bill Bowling's Avatar
I have been running SD for a couple of years. No MAF to tune.
Bill
Old Jun 24, 2007 | 04:56 PM
redtail2426's Avatar
I have been running in speed density for a couple weeks now.I made the switch because i will installing a ported fast 90/90 and dont want any restrictions,including a MAF sensor.I have not been able to tell the difference between the two since i switched.I may have picked up a few ponies up top but cant tell.Idles the same and everything.With the new speed density OS,you can make a really large sized cam idle and drive great.
Old Jun 25, 2007 | 04:34 AM
macca_779's Avatar
Plenty of pros for going SD
Improved Throttle response
More Power
Better Fuel economy
1 less thing to break
Opens up more options for intake designs
Cons.
Acurate fueling is more time consuming to achieve
Can be suseptible to atmospheric drift if not tuned accuratly.
Myths. SD tunes must be retuned for different climates and altitudes. This is sort of true, but the main curplet is inlet temp for VE drift. But thats why we have custom OS's with fields to adjust for this. Altitude. The PCM knows barometric pressure so it compensates for such occasions.
