Anyone else with TPS issues? code 0121
Old Jun 24, 2007 | 12:18 PM
99blancoSS's Avatar
Default Anyone else with TPS issues? code 0121
Keep getting code 0121. I've replaced the TPS but it still trips it. A visual inspection shows everything to be fine. The tuner thinks its being triped due the the cam and vacuum and manifolds pressure not being what the pc thinks it should be and that there isnt really a problem he just need to tune out the code. Anyone else with this issue? He cant find a reason for it and the flash file lead him to his conclusion. Anyone else with a 90/90 big cam and TPS issues?
Old Jun 24, 2007 | 09:41 PM
6-Speed Terror's Avatar
i was told to go under the engine diagnostic > general and under p0121 error max map enter 100kpa, under min enter 0 that should take care of it. this is in hptuners
Old Jun 24, 2007 | 11:46 PM
Shallow Bay's Avatar
Which tuning software is your tuner using? With EFILive, you will want to go to {C3907} TPS Vs RPM Test Lower and lower the lower thresholds.
Attached Thumbnails Anyone else with TPS issues? code 0121-tps-vs-rpm-test-lower.jpg
Old Jun 25, 2007 | 01:00 AM
slmdLS1's Avatar
same problem here, my tuner is using SCT software. this is essentially what my buddy with hptuners said he was told to do with a car he was fooling around with.
