P0103
Old Jun 29, 2007 | 10:14 PM
scottie dont's Avatar
Default P0103
ok so my car is throwing a low voltage output on my mass air flow. what the hell does that mean and how do i fix this? i've had 2 mass air flow's on the car. i tried using a mass air flow translator. nothing so now i need help.
- Scottie
Old Jun 29, 2007 | 10:19 PM
MikeG's Avatar
My 1998 Z Did the same thing when I first got it. I cleared the code a couple times and it just stopped after a couple weeks. Very bizarre, I guess our cars just have goofy MAFs.:shrug:
Old Jun 29, 2007 | 10:21 PM
i;ve tried deleting the code probably 15 times but it will not clear. im not sure what else to try yet
Old Jun 29, 2007 | 11:13 PM
CRAGER's Avatar
Administrator
I moved your thread here to the correct section:
LS1TECH > LS1-LS2-LS6-LS7 PERFORMANCE
http://gearchatter.com/viewtopic9068...a1a220cdde458e
Please post in the correct section next time.
Thanks,
Craig.
LS1TECH.com Staff
Old Jun 29, 2007 | 11:40 PM
Doc's Avatar
Doc
I love your screen name. Very becoming. I imagine you have a re-useable oiled filter of some sort?? Stop hosing it down with oil. Very carefully clean your MAF's tiny bits like you are washing your *****, with an approved MAF cleaner;-short of the assigned cleaner you may or may not be able to aquire at your local autoparts store; isopropal with a q-tip.
Seriously, short of that, check the wires coming from the pcm to the MAF or simply the eng sensor fuse.
