need P0724 help
i already searched. It says brake switch high input. When i open up efilive it says the "tcc/cruise brake pedal switch" is "released". The extended brake switch is "applied". My brake lights work. i can manually make a connection but it still says the same thing. My car was a m6 now it's a a4. Is there 2 or 1 plug that plugs into the bottom pedal switch? because there is only 1 plug but a place for 2. Do I have to wire something into my pcm like a switch or something to make my tcc lockup? I mean could i wire something to trick the pcm to think that the switch is "applied"?
There is a little plug just hangin it's a black and a grey wire. But it doesn't fit into anything i can tell.
